Dimensioning tolerances ?
Does any one know how to force dimensions to carry the zero's on a nominal dimension?
Example: I have a 35mm dimension that shows up as "35"mm, I need it to be represented as "35.00" in order to have my standard tolerances applied.  For the life of me I can't seem to get those zeros to show up!  Any ideas out there?
I'm running R10SP2
RE: Dimensioning tolerances ?
try changing the standard to ANSI. Also, make sure your decimal place precision is set to 0.01
You can get trailing zeros with using ANS.DIMM
BR TPale
