how to model screw in assembly?
hi all,
do someone know how to model screw in assembly ? A spring, a beam, somthin' else ...
and especially in plastic assembly...as screws in Polypropylen assembly ?
thanx
caviac
RE: how to model screw in assembly?
Normally if your assembled parts are modeled whit shell elements and you want stress in your screw you can use beams (with the section properties like your screw) as for bolts or rivets. In the hole you must build a spider.
Hope this help
caviac,
If you are using a solid model, one can use artifical low temperature to create desired tension preload in the bolt/screw.
Gurmeet
thank you all.
