Properties of steel grade HY-GK60 required
Hi all,
Does anybody know the yield stress and ultimate tensile stress of grade HY-GK60 steel? I have not been able to find and reference to this grade but we think the 60 may refer to 60,000psi yield stress.
RE: Properties of steel grade HY-GK60 required
http://www.navsea.navy.mil/specs&standards/gov_ind_revi...+
It is aslo claimed by the manufacturer that it has enhanced (by 40%) bond stresses. For the designs according to the CP114 (UK permissible stresses based code)the anchorage lengths should be between 40 and 50 diameters, depending on the bar diameters, stresses in the bars and the concrete mixture.
Above is based on the GK&N (South Wales) Ltd. brochure from 1965. Hope this helps.
An indented bar ties in with the drawings.
For those who are interested; the bars are 32mm dia with a M30 thread each end and used as holding down bolts for a tower.
Wahmit
