Motor heat exchangers
Have a problem with dust buildup inside tubing of large motor's heat exchanger. Want to have measurements of air velocity/ flow into and out of exchanger to use as an indicator that tubes may need cleaning. Could someone reccomend any sensors/ probes etc which may be used? Has anyone used similar, and where would you mount them?
RE: Motor heat exchangers
Pitot tubes may be considered. They may be installed in ducts.
