UV Coating breakdown into water?
I need to find an efficient way to neutralize UV coating material in water?
I am spraying a water based UV coating on wood products in a "side down draft spray booth" and I would like to be able to break the material down after it is sprayed onto the product and the overflow gets sucked into the filters, onto the conveyor and the flooring.
I am concerned that I maybe creating an environmental hazard.
