minimum water outlet temperature that a cooling tower can reach
Hi, all,
Do you have any idea that the minimum temperature of the water outlet that a cooling tower(natural draft/mechanical draft) can reach?
RE: minimum water outlet temperature that a cooling tower can reach
Area Wet Bulb Temperature + 3 to 50C
This 3 to 50C is called approach of cooling tower. Some manufacturers claim even 20C but I have yet to see such a fictituous equipment.
Some designs even go for an approach (cooling water outlet to the wet bulb T of the entering air) as low as 2.2oC .
For a cooling range of 14 to 20oC, this would result in a filling height of up to 12 m (!).
