Help installing SW 2004 SP 2.1
I have downloaded the SW 2004 SP2.1 so I can do the update.
I am running Windows 2000.
I am getting the problem described in the technical bulletin that the disk is not recognized.
I went to the command prompt and did exactly as the bulletin describes. Nothing happens. It doesn't install.
Please help.
Chris
Please help.
Chris
RE: Help installing SW 2004 SP 2.1
I had the same problem! I had problem getting the syntax just right. So make sure you have the CD in the tray and make sure the syntax is correct - otherwise contact your VAR and see what they say.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
Scott Baugh, CSWP
FAQ731-376
I have just recently upgraded our companies Solidworks and PDMWorks installations. Several of the workstations experienced the same issues. Any Solidworks 2004 disk 1 and disk 3 will complete the upgrade (it does not make any difference for the upgrade recognition), I have used several different sets of install disks and the installs completed without any issues. You just have to remove the disk and clean it off without exiting the installation (this may take a few tries before it does finally recognize the disk), in every case where it happened to me the install continues to completion after this little glitch. It's probably just poor quality disks, but it certainly should not prevent the installation.
However if it does continue to fail then you could follow the instructions and make the administrators image on your network (obviously if your only upgrading a few workstations then your probably not going to want to do that).
John Cole
Sr Mechanical Engineer
Impco Technologies, Inc.
Go figure.
Bradley
