kinematic viscosity
kinematic viscosity
kinematic viscosity
How do I convert from cSt to redwood seconds.  I have kinematic viscosity = 1.20cSt at 40C, and I want to convert to Redwood 1 seconds.
RE: kinematic viscosity
you can find a table ranging from 1 to 21600 cSt here:
http://www.depcopump.com/catalog205/139.pdf
you should be able to interpolate from this one for a reasonably precise number.
so far, I haven't found any conversion formula in my documents, but i will update as soon as and if i find it.
hth,
chris
From the net:
Redwood I, s               cSt
      29                         1.0
      29.4                       1.13
      29.8                       1.81
      30.2                       2.0
      30.6                       2.11
      31.3                       2.4
      32.1                       2.56
      37                         4.5
      55                         11
      86                         20
For 1.2 cSt you'll need to interpolate. There are plenty of conversion tables for KV above 2.0 cSt, some supplied free by pump manufacturers.
visits www.viscosity.com and look in the technical sections for all sorts of conversions.
