More effective - bow thrusters or stern thrusters?
I have personally found that more boats use bow thrusters rather than stern thrusters, for the simple reason that the keel and rudder are located towards the back of the boat, thus making the stern thruster "unnecessary".
However, by observation, the back portion of the boat is usually heavier, due to physical build and equipment stored, such as trim tabs (exterior), generator, batteries, inverters and engines (in engine room). It would be logical to require extra 'help' in the form of thrusters.
At which point is it necessary to use bow/stern thrusters? What are the criteria involved in making the decision? Have there been instances where only stern thrusters are used without the bow thrusters being present?
RE: More effective - bow thrusters or stern thrusters?
I'm probably not terribly qualified to discuss this but I do know a bit about large vessels.
AFAIK the bow thruster tends to be used only during mooring operations. If the ship is self sufficient - ie reasonably powerful bow thrusters it can get alongside okay, high winds and swell cause havoc for an unassisted vessel with under-powered bow thrusters.
Large vessels such as tankers and container vessels usualy need the assistance of a tug to control at least the bow of the vessel. I am not sure if they would even bother having bow thrusters.
Vessels with a high turnaround - ferries, Ro/Ro's tend to be more self sufficient and are usually equipped with powerful bow thrusters to get alongside.
As an example a ferry/rail vessel that weighs 15000 Tonne, might have 10000 kW main propulsion and 1200 kW bow thrusters.
Also the rear of a ship is very manouverable - especially twin screw and becker rudders - can pertty much position a vessel anyway you please with those rudders.
I hope u found this rambling post helpful
Tankers and container vessels would not be able to find a bow thruster powerful enough to even move their bows. The biggest bow thruster I've seen takes 15,000W and that is no easy electrical system to spec out. Thrust is only about 290kg, and compared to the displacement weight of the boat, it's quite insignificant.
But the question still remains, if rudders are quite sufficient, then why the need for stern thrusters?
With the thrusters, you could stop the ship and essentially slide it into place.
TTFN
So have there been instances where only stern thrusters are used without the bow thrusters being present?
TTFN
But no aircraftengr I couldn't say if there have are instances of stern thrusters w/o bow thrusters.
. A twin engine boat or ship will need only a bow thruster and move sideways with no major difficult. .
. A one screw boat will not necessarily need an stern thruster. With some experience you can make the vessel to move sideways without a stern thruster. Of course if you have both, it will be easier.
. The bow thruster is relatively easy to install in the bow because the witdth of the hull -in the region where you need to install the tunnel for the bow thruster- is not a big one and you do not have other machinery, shafts or equipment in that area.
. In the stern, the installation is mainly more complex because you have shahts, machiney, engines pipes, etc and usualy the stern is wider with some exceptions so you need longer tunnels, etc. Mainly the stern is thin only in the places where you have the main shaft in one screw vessels.
. No matter what is said before, there are ships with both stern and bow thrusters.
. Contrary to popular believe, a lot of big ships use bowthrusters with pretty big HP
As Fleet Manager for a previous employer, one of our vessels had a rotating nozzle in the stern (no rudder) and a bowthruster. The rotating nozzle acted as a sternthruster. I don't believe I've ever heard of any ship with sternthruster only installed, although this particular vessel operated fine and maneuvered well without utilizing the bow thruster at times.
Rgds, ktm5
Any other comments?
Cheers!
Likewise, most stern thrusters are probably inappropriate for underway steering.
TTFN
How much more powerful anyway? The stern is usually heavier for the common bow-up position. I figure it requires more power. However, the stern already has the assistance of the rudder. How do I balance the necessity of stern maneuverability?
Angel
Today more and more ships are equiped with podded propulsion where several solutions allows you to rotate the propeller and redirect your thrust in any direction and really removing the need for a stern thruster (and rudder): http://www.masa-yards.fi/publications/pdf/Motorship2000.pdf
TTFN
On some ships with twin engine installation, the distance between the shafts is so relatively short with respect to the length of the ship that is hard to move the ship sideways using the engines and rudders alone. This dictate the use of stern thrusters or tugs during docking and undocking, etc.
The same amount of thrust applied at the extreme outboard location would generate a much larger torque.
TTFN
“At which point is it necessary to use bow/stern thrusters? What are the criteria involved in making the decision? Have there been instances where only stern thrusters are used without the bow thrusters being present?”
1. I believe it depends on the degree of maneuverability required under the specific seakeeping circumstances occurring during the docking/undocking procedure.
2. Some of the criteria have been discussed in this thread, being existing propulsion design limitations, sea state experienced, air draft of vessel vs wetted surface area, size, etc… Each vessel has it’s unique turning and maneuvering characteristics. Other criteria not discussed yet here are CAPEX vs ROI, will the thrusters preclude use of harbor tugs for docking and undocking, pilotage requirements for the specific ports to be visited, etc…
3. I don’t believe there has ever been a sternthruster installation without a bow thruster also.
Rgds,
ktm5
1 To steer the bow
2 To steer the stern
1. To steer the bow:
On one engine installations, at slow speed is almost impossible to steer the bow: You need a bowthruster or a tug in close quarters because as soon as you use your engine the ship will move astern or forward.
On twin engine installations, you can use the moment that develops with different setting of the propellers thrust and the rudders to move the bow. The dimensions that determine how easy you will be able to control the bow are the separation between the shafts and the total thrust you can use on each shaft.
When the L/B relationship is relatively low, and the shaft are relatively far from each other, you can very easy turn the ship and "walk" sideways using the main engines and rudders
If you look at any sportfisherman, tug, etc, you will see how "easy" they turn and dock relying only on the engines and rudders.
On very long ships, with high L/B relation, the maximum moment you can get is relatively low so it makes a lot of sense to use a bowthruster.
2. To steer the stern:
Even having only one engine, you can help the ship a lot using the propeller and ruder. Having a bow thruster, the ship can be steered without a stern thruster or tug using the main engine. One main consideration will be the ability of the propulsion plant to switch back and forward.
If you have a twin engine installation, the need for the stern thruster is dubious except in the case when you need huge amounts of torque to steer the ship stern or you can't or do not want to use the main engines to steer the stern. The distance between shafts is not so critical as is the amount of thrust you can apply on each direction. One engine holds the ship in place while the other move it to one side or the other.
If you can use your main engines and they are flexible enough - controlable pitch props, electric motors, etc- the stern thrusters do not represent a big advantage: For the stern thruster and the propellers, the lever is almost the same relatively to the center of the submerged area of the ship but the main engines carry hundreds and hundreds of time more power and the propellers can develop a lot more thrust. You can move the stern sideways without any headway if you choose to.
Of course, when you have both bow and stern thrusters, the handling of the ship is a lot easier and safer, you do not need so much to relay on somebody's skill to dock the ship and the probability of an accident is lower. Also you do not stress the propulsion system.
There are a lot of considerations when you are trying to make a decision to install or not certain type of thrusters. I agree 100 % with KTM5's considerations .
I never found a ship with stern thruster without a bow one.
I have seen hundreds with bow thrusters and no stern thrusters.
If somebody is interested in a deeper knowledge about this topic and ship maneuverability in general let me know.I might write a little bit deeper about this and send to the e-mail of the interested person.
In a typical offshore support vessel required to Dynamically position you could find three azimuthing thrusters at say 2Mw each and three bow tunnel thrusters at about 1.2 Mw each this may well be an indication of their relative effectiveness?? We need the Naval Architechts for this one.
When a ship maneuvers, the rudder changes the angle of attack of the hull. The hull then generates a hydrodynamic force (lift) in the horizontal plane which is responsible for causing the maneuvering acceleration. The center of lift is typically 1/4 to 1/3 LWL aft of the forward perpendicular. A stern thruster is farther away from the center of lift of the hull, so it's effect on maneuvering is greater than that of a bow thruster.
A bow thruster's effect on maneuvering decreases very quickly with increasing speed.
Colin Pitts
At this time, VERY FEW Navy and Coast Guard vessels have thrusters of any sort, with buoy tenders being an obvious exception (and the only one I can think of off the top of my head).
TTFN
That means the maneuverability is less critical at this point (unless you're doing a stunt act in a movie).
But when you are constricted for space and yet need power to move, it appears that the bow thruster comes in handy. Guess that's why bow thrusters are used more often.
I personally have never dealt with a stern thruster but i have worked on several bow thrusters. The point that was made about large vessels not having them is not true. As a matter of fact, the largest oil barge in the world has two seperate ones, each with its own engine. And let me tell you this, I would NEVER design a vessel with one of them, the maintenance is a nightmare and very expensive. For a true cargo vessel, forget the thruster and get a tug. Most cargo ships use two tugs when docking, even when they DO have a bow thruster. Also, dont forget that the tunnels where these things are installed take a beating from the water flow forward and make it hard to keep the coatings on them. In these areas, erosion is as big a factor as corrosion.
Lastly, dont forget the golden rule of Cargo Ships. Every square inch of space, and every pound of weight used for something installed on the ship, is that amount of cargo that cant be carried. Its all about money people.
First and foremost a good ship driver with a twin screw ship does not need a bow thruster or tugs. Both are relied upon for safety. But then of course, the most valuable assest during mooring is the ship's pilot. He comes aboard prior to entering the harbor.
However, mooring a large vessel is just the opposite of parallel parking. You make an approach 30 degrees relative. Come to all stop about 400 yds. Dead in water about 10 yards. Throw over #1 mooring line.
Take tension on #1 line.
Walk stern over. Throw over #6 line. Take tension on 6 line.
Getting underway, you twist the ship. Similar to a bulldozer or skid steer. One track goes forward and the other reverse. If you are starboard side to, starboard engine ahead 1/3, port engine back 1/3.
If ship has gas turbines (LM2500), then shaft always rotates in same direction. CRP screws rotate to full pitch ahead (over 20+ feet) and back to about (over 15+ feet).
One thing everyone has forgotten is sail area. Large Naval vessels project a tremendous amount of sail area. Think very large main sail for a sail boat.
In a 30 knot wind at 90 or 270 relative, if the ship's pilot orders you to deadstick it in, then you will need four very large tugs to push you pierside.
With the new electric pods, many thruster applications are becoming obsolete.
Likewise, a ducted propeller doesn't need 3 to 5 kts for rudder effectiveness. Knort nozzles have been around for quite some time.
Designing a ship is one thing. Driving it is another!
Todd
Former Navy Officer Ship Driver
Naval Engineer
Todd
www.oxilume.com
Another example of where position holding is paramount is in ROV (Remotely Operated Vehicle) operations. These are remote control underwater robots typically capable of upto 3000m (10,000 ft) seawater depth.
Such a vessel is the world class offshore construction vessel the BOA Deep C, operating out of Norway. A 13,000 ton vessel, equipped with two work class ROVs and capable of deploying equipment upto 250 ton in all sorts of water depth. This has two bow, two stern thrusters and one retractable azimuth thruster. An incredibly sophisticed vessel! See:
w
For your info, there is also another type of propulsion system, completely independent from conventional prop/thruster systems. This utilises rotating 5 blades extending below the hull of the ship. As the blades rotate the pitch angle is altered and the blades in effect 'swim' through the water. As this pitch angle can be directed towards any azimuth angle, the vessel can move in any direction, or rotate, whatever you want. This system patented and built by Voith Schneider has been about for about 80 years and is typically used for pilot boats, short distance passenger vessels, etc. See:
http://
Hope this is of help to you.
One thing is a Naval ship, with mainly hughe power to displacement ratio -compared to merchant ships- more than one shaft, very good inherent maneuverability and a moderated relative sail area and another is an empty cargo, or tanker ship.
To maneuver a cargo ship or a tanker in copmplex meteo conditions is a nightmare and the cause of some ports just do not allowing maneuvers of certain ships even with the help of powerfull tugs and or bowthrusters during certain meteo conditions.
The inertia, and the reaction time since you apply your own power and/or from the tugs to the moment you get some movement are really hughe. The wind and current forces are really hughe.
I have seen a lot of accidents during maneuvers even with tugs present, destroying ships and piers and costing lives. The human error is the main cause of the accidents, but of course, the meteo conditions at the time you are maneuvering and the characteristic of the ship you are running and the layout of the piers sometimes induce such a high stress on pilots and captains that errors occur and accident happens.
Even if you have twin screws, on a big container or passenger ships the distance between the shafts is not enough to control the bow -even at relatively high power settings- unless there is no wind or a very moderate one. Sometimes the thruster is a necesity of the ports the ship is visiting. If a ship will go to ports that do no have tugs and the pier layout is difficult, and the meteoconditions are mainly rough, when you are designing the ship probably you will put thrusters of some kind to make the ship safer.
As oxilume pointed, the electric pods made the stern thrustes necessity dubious at best, but even in this case, sometimes a bow thruster remains a necesity.
R.A.
Structural Analysis Engineer
Excelnet
in case you want to keep a very precise position over the seafloor, and your main engine is too big to react as fast as you want for this
or in the case that you do extensive backward maneuvers at low speeds, like channel barges.
I particularly don´t like thrusters, they are made, and installed for faster and easier maneuvers, but if you can´t dock you ship without them due to meteo conditions, or other factors, depending 100% on them will get you into problems sooner or later.
I am only talking about yachts and small ships, I now very little about tankers and the likes.
Jabonet
