How to separate caps with same height and different diameter
There are two different caps that we need machine to separate them. They are the same in height(around 50 mm) and different in diameter (150mm and 180 mm ). The parts are made in plastic and mixed with same amounts. Can you give me some thoughts to build this machine?
RE: How to separate caps with same height and different diameter
Try speaking to manufacturers of Vibratory Bowl feeders (well thats what they're called in the UK) these folks are used to these sorting problems and will provide a nice simple solution.
http://216.255.148.39/#
