Proper Fuse Size?
Proper Fuse Size?
Can someone tell me/or point me to a web site that I can get information on figureing out the proper size fuse for engine block heaters like those used on emergency generators.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Proper Fuse Size?
A typical 5kW heater might be rated 240 volts. 5000/240 = 20.8A. For NEC areas, 20.8 x 1.25 = 26.0, so you would need 30A fuses.
