how to fill two colors on a single object in two regions?
Hi, guys:
 I have a cube which is blue. I want to draw a circle on one of its surface and fill a red color.
 I can not find the fill tool button. Seems one Q/A concerns the tool bars, not try that yet...
 I'm new here and new to solid edge. I tried to search the historical Q/A about my question, but didn't find a close answer.
  Thanks a lot
  Liu
RE: how to fill two colors on a single object in two regions?
Do you have any particular reasons for doing so?
No big reason, just want to put a drawing or label-like stuff on an object's surface so it can be seen in 3D view. Do not want to make two objects... or maybe make another object with height = 0?
I use soild edge v12.
It will work if the height > 0 (ex. 0.0001)
Care to elaborate a little more on how does that help you in your work?
