Material style change
After I save my drawings I can not change part material (material style). The error I am getting is:
“[ERROR] Cannot modify the library file (file path and name)“
Would anyone be able to explain what is the problem?
Thank you in advance
Bob
Bob
RE: Material style change
Sean Dotson, PE
Inventor Tutorials & More
www.sdotson.com
One good idea is to setup a project for library management in which your normal library folders are NOT libraries but are normal active project folders. This way you have a mechanism for keeping your libraries clean and tidy without the hack of moving stuff around just so you can maintain them.
Probably a good idea in a multi-user office to restrict access to the library project.
There are lots of people out there who are unaware of the documentation on the Inventor CDs. On the Inventor 8 Pro CDs for example on disk #1 in the \bin\acadfeui\docs folder there are a lot of usefull docs. Very helpful on file management is the one called 'Autodesk Inventor File Management.doc'.. Also usefull is 'Inventor8_managing_your_data.pdf'
Amazing how many people dont know these file are there hidden away in such an obvious folder on the CD
Ralph Tilbrook
Sean Dotson, PE
www.sdotson.com
Your Webbased mCAD Discussion
www.mcadforums.com
