Centroid relative to sketch origin
Hello ,
Is it possible to draw a centerline (or a point) through the
Centroid ?
With section properties i can se the Centroid relative to sketch origin but i can't add a relation.
thanks a lot
RE: Centroid relative to sketch origin
i found a way to do this.
I draw a point and make a equitation of the distance of this point to the origin.
is there another way ?
You can always create a plane at the depth of the z axis of the centroid. And then simply place a point at the xy coordinates on that plane.
Make a point in 3D sketch.  You can edit the absolute (X, Y, Z)position of the point at the bottom of the property manager when the point is selected.
-OR-
You can dimension the point in 3D by adding dimensions fom the point to each of the principle planes.
"Great ideas need landing gear as well as wings."--C. D. Jackson
http://www.EsoxRepublic.com
thanks all for the reply
the thick,
the centroid that i need , is the centroid from a sketch.
the sketch (symetric)is driven and have no features.
with the section properties i can see the centroid.
what i did, is calculate the Y-position and link a formula with the equitation to the dimension:
Y = ((y1*area1)+(y2*area2))/(area1+area2)
