Design an online moisture absorption desorption system using waste hea
Hallo all
I want to design a system using waste heat from a process to regenerate the bed of a continuous absorption desorption unit. It consists of two beds in which one bed is regenerated while other is in use(pressure swing cycle). The unit is used to remove moisture from oil free air. Any help will be appreciated.
RE: Design an online moisture absorption desorption system using waste hea
