normal confortable temperature for 90% relative humidity
What would be the normal temperature one shouls set the thermostat for cooling if the relative humidity is 90 % or above ?
is there somewhere in internet a web page where I can see something like a table for a relationship between relative humidity and ideal thermostat temperature settimg ?
Where can I find also a table for heat generation of different things like fluorescent ballasts or even a human being ?
Appreciate very much if you can help me out with these questions .
RE: normal confortable temperature for 90% relative humidity
Join ASHRAE (American Society of Heating, Refrigerating and Air Conditioning Engineers, Inc.) With your membership you receive a collection of four books (one book per year). Remain a member until you receive the complete set or order the complete set upon you first years membership. Anyway once you have these books you have a wealth of knowledge at your fingertips.
To answer your post study a psychrometric chart. It will tell you what the cooling effect will have upon a given RH
Good Luck
pennpoint
However, if you have some form of mechanical cooling in the space it seems unlikely that you would have such high RH.
You can buy the ASHRAE handbooks without becoming a member. You can also buy the four book set on one CD.
Theres a process called evaporative cooling. So if you were to have a fan that can blow the plates off the tables and at 90% humidity you might get a reasonable comfort condition! OK thats not funny.
“It’s not the heat, it’s the humdity”
ASHRAE Standard 55
Comfort zone:
•67° to 82°F
•35% to 60%rh
One ton= 1 ton of ice per day
= 12,000 Btu/hr
