I need to make a small speaker sound lauder
We instaled a small speaker in to a electronic board, but it sounds to low. How can I make the speaker sound louder.
RE: I need to make a small speaker sound lauder
Run more audio power?
Get larger speaker?
TTFN
Hi Joe,
          How much wattage will the speaker take, it should be labeled on the back of the speaker?  What is the device thats driving the speaker and whats the voltage to the device? Also there may be a current limiting resistor on the output device. You need to include more info for us to help.
                                                -elf
Dear Joserois,
You can find more power speaker or you can use Amplifier .
What is your problem? How type speaker do you use?
Kerem SENCAN
Sencankerem@hotmail.com
Istanbul-Turkey
Is it a coil type speaker or piezo.  We had a product that used a piezo and the board had a pot that adjusted the frequency for the resonance of the transducer.  This made it quite loud but the products started failing in about a year.  No only did the engineer operate it at over the rated voltage but he tuned it to resonance. Using a microscope it was easy to see the crystaline structure of the wire on the piezo where it fractured.  Changing the frequency can increase the efficiency if you don't have the space for a cone.
