How do I choose a network printer in a macro?
I have a macro which will print an excel worksheet. I have installed it on another computer in our network but the local printer for that computer is an older model which will not print borders around excel cells or print color.
How can I have this Excel macro choose a specific network printer rather than the default printer. Currently we have to manually change the default printer before running the macro.
An alternate plan is to get the older printer (HP Laser Jet III) to print the borders and use shading in place of colors.
Any help is appreciated.
RE: How do I choose a network printer in a macro?
Just execute
rundll32 printui.dll,PrintUIEntry /y /n "printer" /q
for setting the printer you wish as default.
Print
at the end of your macro just repeat again for re set the right one.
Application.ActivePrinter = "[Printer & path]"
It all seems so simple now.
bpeirson.
' Display printer setup dialog
Application.Dialogs.Item(xlDialogPrinterSetup).Show
Hope this helps
Dave
Brad
hope this helps
