Accumulator Function in an Automatic Transmission
I reciently had to open up a MOPAR 727 to replace the reverse band which had been damaged while backing a horse trailer up an incline with low fluid, (my wife did it but it was my fault). Upon removing the valve body I found the accumulator spring missing. Now at first I thought that it might have fallen out and rolled under something but a check on the position of the accumulator piston said otherwise, it was in the fully extended position right at the top of the casing. My question is; how does this affect operation as the only unusual operation noted has been a harsh manual 2-3 shift at light loads, (with a driveline clank). My guess is that it should even out pressure spikes and dips.
Could this be a "Hot Rod Shift Kit Trick"?
The prior owner had the transmission professionaly rebuilt.
RE: Accumulator Function in an Automatic Transmission
John
Some of the performance shift kits rely on spacers, plugged passageways, drilled spacer plates, reversed pistons, milled out valve bodies, and so on.
The automatic transmission is either one of the simplest or most complicated devices today, and I take my hat off to the first engineers who designed a good production model in the late 40's (I know there were ones earlier, but really good models didn't come out until the late 40's).
Franz
