Problems saving with Microstation Version 8.1
Hello all,
  We recently upgraded to microstation version 8.1 and are experiencing problems with saving drawings to the LAN. The automatic save feature no longer works, and when you hit the save icon sometimes the file will save, and sometimes it will not. We did not have this problem in the past, and several designers have lost hours of work on various drawings. Has anyone else experienced this problem, and is there an upgrade or patch available to remedy this problem.
                                Don
RE: Problems saving with Microstation Version 8.1
Contact Bentley.  We had that same problem and they seemed to fix that with the later versions.  We especially had that problem in the 'dwg' mode.
