Need help with a transistor
I want to switch a transistor (as below) that will supply current via the 100R resistor when power is applied.  However, I would like to be able to turn the transistor OFF and ON using a micro.  Any ideas?
 _______________  +5V
_|_           |
 |________|
_|_         \
| |          _|_
 |           | | 100R
 |            |____________ rest of cct
_|___________________ GND
RE: Need help with a transistor
Put another transistor (or FET) between the lower base bias resistor and ground.  Control the new transistor/FET with the micro.
 _______________  +5V
_|_           |
 |________|
_|_         \
| |          _|_
 |           | | 100R
    \|_______/\______ micro
 / ¯          |_______ rest of cct
|_________________ gnd
I think this is what you mean.
The problem with this is that the micro will ultimately control the 100R load.  What I need is when power is applied, the PNP transistor is on, regardless of the micro.  Then I need to turn the PNP transistor OFF with a micro.
Using the schematic you just drew, add a pull-up resistor to the second transistor's base.  On start-up, the transistor will conduct and turn the whole shebang on.  To turn it off by way of the micro, pull the base to ground.
