Fillet consist of lines CATIA V4.2.4
I have a problem with radius after creation view based on model. After create model (with some fillets) when I make a draw view (AUXVIEW2>QUICKDRW>CREATE) area where should be radius is "degenerate" - consist of a lot of lines instead of one fillet. But when I create simple breakout after that command fillets are normal (only in the area of breakout!)
how can I fix this error?
I use a CATIA V4 RELEASE 2.4 FR 4.2.4
Grzegorz
Grzegorz
RE: Fillet consist of lines CATIA V4.2.4
I wrote that I get small lines insead of the curve. That are real straight lines - I can measure it, erase etc.
try decreasing the discretenization value in GRAPHIC+SPEC ELEMS and selecting the solid, decrease the small value by say 10 i.e. if 0.2 set to 0.02 and recreate the view. This may help.
Zimbaent
Now it works.
Grzegorz
