select by fill?
select by fill?
Hi!
Is it possible to select shapes by fill?
Shapes are within the same level and has the same outline (color, weight) but different fill color.
Thanks!
Thanks!
RE: select by fill?
RE: select by fill?
The problem is when I have shapes with the same outline attributes and different fill colour as Microstation use outline attributes as shape attributes.
RE: select by fill?
