validation of results
I'm a fairly new user of Pro/Mech but an experienced design engineer, and I am slowly working on my confidence level of the results that I obtain. I design things that mostly use plates so I compared the results of some round and square plates in mechanica to roark. A little disappointed so far, but maybe I am expecting too much?
Best results for a round plate (uniform normal pressure load)was to use a solid, compressed into a shell. Stress compared well (~4%) but displacement was off by about 12%.
Best results for a square plate (same loading method) was again a solid compressed to shell but in this case the deflection was right on with stress off by 15%.
Results using 'thin' protrusions was poor. Note that I varied how constraints were applied (edge & surface) and no real difference was noted. Square plate width/thk=40, round plate dia/thk=12.5. I applied light loads to ensure staying within elastic range and used 'standard' mat'l properties.
Are these results typical? I realize that these are only approximations and that integrated mode (all that I have) maybe makes the approximation even more approximate, but these usefulness of these results seem a bit questionable to me. I have spoken with some engineers who do not even question the results. Maybe I am too old or conservative to do that, but I would appreciate feedback as to others results.
Thanks in advance for your help,
Bob
Bob
RE: validation of results
You can install the validation models supplied on the Mechanica CD which do exactly what you are trying - validates simple analyses against theory. Maybe try these to get confidence, and examples of how these models were loaded and constrained.
