Cosmosworks Thermal Error
Good afternoon,
I'm running a thermal analysis on an assembly today that I haven't worked with in months. Back in September the analysis ran fine. Today if I run it (on the exact same assembly file) I get the error "Execution abort in DIRCOS".
I've tried running an analysis on a new assenbly using  only a couple of the 21 parts and no error. I've rebuilt my assembly from scratch (all 21 parts) in a new file and the error returns.
Any ideas?
SW 2003 SP5
CW 2003
Killswitch
RE: Cosmosworks Thermal Error
Yup.  Ask your VAR for support.
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
A hobbit's lifestyle sounds rather pleasant...... it's the hairy feet that turn me off.
JNR
Not everyone has VAR support! My employers are too cheap ...too Short Sighted ...too UNCARING ...TOO STUPID (...take deep breath ...count ...1,2,3,4,5,6,7,8,9,10 ... breathe out ...OK ...I'm back) to see the benefit of paying for support ......hence the reason I joined this forum. It is probably the next best thing to VAR support ...maybe even better as it's free
killswitch
Try running an analysis on each part individually to see if there is a specific part causing the problem. Alternatively, open the assembly & suppress all but the first feature, run the analysis, unsuppress the next feature, run analysis, etc. I realise this might take a lot of time, but it's the only thing I could think of.
CorBlimeyLimey, Barrie, Ontario.
I intend to live forever - so far, so good
FAQ559-863
I was able to get the analysis to work but not until I rebuilt the assembly 3 times from scratch. The last time I added a part, ran the analysis, added a parameter, ran, added a part, ran , added a parmeter, ran, ... until the entire assembly was created and all the heat transfer parameters were present. This took most of the afternoon but I finally had an assembly that didn't crash.
Kind of sour on Cosmosworks right now!
Thanks for all the comments,
Killswitch
Killswitch  or CorBlimeylimey  How do we get the symbols to show here like Diameter?  the zero with the slash?  Are there other symbols?  I am very new here.  Is there someplace I should go to read up on the use of the forum?
Thanks, John
toolmantwo
Just Cut & Paste the standard Character Map keys supplied with Windows or use the "ALT" key equivalents.
° = "ALT" key & 0176
± = "ALT" key & 0177
Ø = "ALT" key & 0216
from Barrie, Ontario.
I love defenseless animals, especially in a good gravy.
FAQ559-863
Ouch......  well when something really bites them in the @$$ - like something fails, everyone else to 3 revs ahead and you are no longer compatible, yadda, yadda ,yadda.... you probably know them all.  Then you can tell your cheap, arrogant, shortsighted employers you told 'em so and if they want to get the job done they had better start budgeting for support and hardware upgrades.  Since you are the victim, you have my sympathy.  It never ceases to amaze me that people will buy a complex piece of software that they know is on a constant upgrade path, and expect not to maintain their investment and yet rely on it to work forever.
CorBlimeylimey
I tried that "Holding down the alt key and then to key in 0176, but it did not work.  Sorry but what am I doing wrong?
toolmantwo
I don't know! Are you typing the 0 as alpha or numeric? It should be numeric (zero).
Try it in a regular word processor (Word, WordPerfect, Notepad, Wordpad,  etc). If it doesn't work in those, the problem is with your computer ... or you!
Also try cut & paste from the Character Map in Accessories.
FAQ559-863
I think it makes a differnt as for what Font is being used, doesn't? If you use that combination using a differnt font you will get something else. See character map. Which is found under your Programs\Accessories\System Tools - I'm using XP Pro
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
I found some in Word under;  Insert, Symbols, under a few fonts.
But they show up here as ? and ? and ? when I do cut and paste into here.   Well, just skip it for now I can use the words instead.
Thanks guys
killswitch
Using COSMOS in assemblies can be tricky, at least for stress analysis. I have no experience with thermal studies but I gess the problems can be identical.
Try to create alternate meshes, with alternate options and sizes, I try to figure out if you improve the model and avoid the error.
If your model have parts with very different sizes and thiknesses, COSMOS can experience som difficulties creating a proper mesh.
Carefuly check for interference between parts. Even a micron sized interference can prevent the processor to work successfuly. In this is the case, try a micron sized gap (this works better than the interference)
Good Luck
macPT,
My issues with COSMOS is that a thermal analysis will run perfectly on an assembly one day (messing and results) and completely crash on the same assembly the next day (simply open the assembly and run the analysis). Once COSMOS "decides" it doesn't like and assembly, there seems to be no way to recover it. I always have to start from scratch. No that I know this, from working with COSMOS for the past year, I ALWAYS make copies and back-ups to save time when the crash occurs. Not the ideal solution.
Killswitch
killswitch
That's strange! Never heard of such behaviour.
Check Cosmos site and verify if there's a new SP available.
If you can't contact your VAR, you will need to find out for yourself! In this case try to carefuly run some experiments and be more specific.
For example: does this happens with other assemblies? can you filter a part or parts wich lead to crash and analyse them carefuly? what do you axactly mean with one day and next day (you run the first time and crashes in the second?)? can you run this in other computers?....
I think that, with some trial and error (and time!) you will find out what is happening. Meanwhile you can keep us informed of the results, so we can come up with some idea.
