DWG export and SP2.1
I'm having major scaling/dimensional/text errors when exporting to DWG with some fairly basic drawings (using SP1). Has anyone else noticed anything like this? If so, does the new service pack seem to help?
Otherwise, perhaps I misplaced a setting somewhere--but I haven't had this happen before.
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
RE: DWG export and SP2.1
Any information would be appreciated?
Thanks, Jim
If your problem has to deal with this issue that Theophilus is talking about in the begining of this thread - then below applies.
SP2.1 is still the latest SP out. If it wasn't repaired in SP2.1 before, then it still isn't repaired in SP2.1 now.
If it doesn't, then you need to make a new thread concerning this issue.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
For the scaling issue, I simply made the drawings full scale (very huge--120' for one view) and then had no problems after applying SP 2.1 for the other issues I was experiencing. My VAR told me that everything is 1:1 with AutoCAD, so it doesn't import scaled items according to their scale--best practice is to stick with full scale when you plan to export to ACAD.
Jeff Mowry
