I was trying to determine density o
I was trying to determine density of the following chemicals:
1) Natural gas
2) Diesal
3) Propane
Also, what type of firing (front, tangential, opposed) for most space heaters, boilers, hot water heaters?
1) Natural gas
2) Diesal
3) Propane
RE: I was trying to determine density o
The density of liquid propane at 15-20 °C is 505 kg/m3.
The density of any gas will vary with the molecular weight, temperature and pressure of the gas. The following equation can be used to calculate gas densities in kg/m3:
kg/m3 = (MW / 0.082057) (atm / °K)
where:
MW = molecular weight of the gas
atm = absolute pressure of the gas, in atmospheres
°K = temperature of the gas in °K = 273 + °C
As an example, assuming the gaseous propane (MW = 44) is at 20 °C and at 1 atmosphere of pressure:
kg/m3 = (44 / 0.082057) (1 /293) = 1.83
As another example, natural gas is usually about 95% or more of methane. Assuming it is 100% methane (MW = 16) and that it is at 20 °C and at 1 atmosphere of pressure:
kg/m3 = (16 / 0.082057) (1 /293) = 0.67
You can plug in your actual gas temperatures and pressures into the above equation and thus calculate your gas densities.
Milton Beychok
mbeychok@xxx.net (replace xxx with cox)
(Visit me at www.air-dispersion.com)
