Need to reinstall MSVCRT.DLL but its in use by Windows
Please help!
I'm getting the following warning message when I launch most applications (MathCAD, IE5, AutoCAD, etc)
"The procedure entry point ??_U@YAPAXI@Z
could not be located in the DLL MSVCRT.DLL"
I need to reinstall MSVCRT.DLL but as its in use by Windows NT it wont let me!
CAP GEMINI ERNEST & YOUNG COULD NOT SOLVE THIS PROBLEM!!!
(their solution is to reformat the hard drive!)
I would be most impressed and appreciative if this can be solved??
RE: Need to reinstall MSVCRT.DLL but its in use by Windows
I won't take any responsibility for the results, try to start your computer from boot diskett (create it if you don't have one) and install *.DLL from the dos prompt. Again, I know about computers just enough to get in trouble. Good luck!
yakpol
