Wire size comparative chart
4
I'm working for an engineer battalion in stationed in Baghdad working on reconstruction.  I need a handy wire size comparison chart relating the common AWG to the sizes usually found here (6mm^2, 10mm^2, etc.)  I don't have many technical books and I can't really get books or journals very fast over here so references to those won't help me now.  We could only really bring our battle rattle.  But if any of you know of a chart online somewhere I would appreciate it.  I need it to cover sizes from #18 AWG through 4/0 if possible.  Thanks for your help!
CPT Steve
RE: Wire size comparative chart
Steve,
The chart is available on ABB's web site, however you will have to search for it as I cannot remember just where it is located.
Midos
Suggestion: Some approximations will be needed since the sq mm sizes are standardized just like AWG sizes. Use the closest bigger sq mm size to stay on the safe side.
It appears that one of the above links is practical, namely:
http://www.lexproducts.com/wireconv.htm
Also, there are some official guidelines available: e.g.
http://www.nema.org/docuploads//441561B3-9287-41BC-8D16...
http://www.generalcable.com.au/Technical/10.1.4.3.1.pdf
http://www.astm.org/DATABASE.CART/REDLINE_PAGES/B682.ht...
etc.
amp/euro(mm2)/CALC(cm)/AWG/US(cm)/US (mm2)
-     0.75         1,480         18      1,620      0.82
-     1.00         1,974         16      2,580      1.30
15    1.50         2,961         14      4,110      2.08
20    2.50         4,935         12      6,530      3.30
30    4.00         7,896         10      10,380     5.25
40    6.00         11,644        8      16,510     8.36
55    10.00        19,740        6      26,240     13.29
70    16.00        31,584        4      41,710     21.14
80    25.00        49,350        3      52,620     26.25
95    -----        ------           2      66,360     33.61
130   35.00        69,090        1      83,630     42.39
150   50.00        98,700        1/0    105,600    53.49
175   -          -                  2/0    133,100    67.42
200   70.00       138,180        3/0    167,800    85.00
230   95.00       187,530        4/0    211,600    107.19
255   120.00      236,880        250    250,000    126.64
285   150.00      296,100        300    300,000    151.97
310   -          -                  350    350,000    177.30
335   185.00      365,190        400    400,000    202.63
380   240.00      473,760        500    500,000    253.29
420   300.00      592.200        600    600,000    303.95
460   -          -                 700    700,000    354.60
475   -          -                 750    750,000    379.93
note:ampacity is for copper wire
note:CALC US (cm): is millimeter square converted to U.S. circular mils
(mm2) is Millimeter squared
(mm) is circular mil
US (mm2) is circular Mil converted to millimeter square
note:European designation of wire: example 3x70+1x35 means that the circuit is multi-conductor cable containing three conductoRs, each 70 sq mm in size and a ground wire of 35 sq mm. this 200 amp cicuit is equivalent to our 3/0 cable with one number 1 ground conductor
My small bit to help our Guys over there.
Good Luck
correction to my last posting:Under the notes- should be (cm) is circular mil instead of (mm)is circular mil
Suggestion to the previous posting: It is better to use cmil and kcmil for circular mils and kilocircular mils since cm normally stands for the centimeter.
I was trying to get the information to fit on the page as quickly as I could. But it is a good point.
If you email me at rod@mcmahon.co.nz I will send you an Excel spread sheet converter that sizes cables using all mm2 sizing
