1600kW motor Autotransformer start sizing
Could anyone tell me how to size the autotransformer size for starting of 6.0 kV,50Hz,1600 kW induction motor by autotransformer start method.The tap voltage required is 80%,65% and 50% of nominal line voltage.
Thank you
Thank you
RE: 1600kW motor Autotransformer start sizing
This should get you started.
http://www.rale.ch/Examles/CAL0013e/Cal0013e.html
for the autotransformer sizing
