Please help! I'm getting the follo
Please help!
I'm getting the following warning message when I launch most applications (MathCAD, IE5, AutoCAD, etc)
"The procedure entry point ??_U@YAPAXI@Z
could not be located in the DLL MSVCRT.DLL"
I need to reinstall MSVCRT.DLL but as its in use by Windows NT it wont let me!
CAP GEMINI ERNEST & YOUNG COULD NOT SOLVE THIS PROBLEM!!!
(their solution is to reformat the hard drive!)
I would be most impressed and appreciative if this can be solved??
RE: Please help! I'm getting the follo
Get to a COMMAND PROMPT aka DOS.
Delete MSVCRT.DLL
Copy MSVCRT.DLL from your disk, cd etc. to the location where it was located on your harddrive
ReBoot
Good Luck
thanks anyway, Rich
Yakov
Hope it will work!
Luc
What you could do is:
1) reinstall the applictions which are giving the message, Autocad, MCad, Iexplorer, maybe one of the installations will fix the problem.
2) NT will not work with a dos command unless you set up a dos boot system, and unfortunately dos can't acces NTFS partitions.
If you have enough drive space, make an extra drive and install a second copy of NT on that. You will have now a dual boot machine. Boot in the 2nd NT mode and now you are able to make modifications in the system directory of 1st NT mode. Make back-up of the files you are replacing, so you allways can revert to a prior situation.
Hope this help
Steven van Els
SAvanEls@cq-link.sr
thanks for your info, but unfortunately our IT sub contractors took away the machine and reformatted the disk. However, like SVANELS pointed out the machine count not be started in DOS mode due to the absence of the DOS mode partition, but Til's solution may have worked. Our IT people should have considered SVANELS dual boot solution (thanks for that!)
Kind regards all,
Daveo
