Need qty note...
Need qty note...
Need help finding a way to create a simple note that parametricaly shows the qty of the currently set drawing.
RE: Need qty note...
Why not use a balloon? Do you have a QTY parameter already in your parts? Is this note on a piece part or assembly. The QTY parameter can be added to the family table and different values given for each variation. You can have your note read &qty if it is a piece part, in an assembly you many have to add the part under views, drawing views, add model and pick the model that you want to show the QTY for. Then your note will read &qty. It may change to &qty:#.
Hope this helps,
Tofflemire
-Hora
What about creating the BOM again and just filtering out the parts that are not required, you can customise the BOM to have thae parameters you require.
Hope this helps.
maybe only a drafter
but the best user at this company!
