Copy/pattern sketch segments in SLDDRW?
Here's the deal, I created an assembly that is welded. I do not use the weld features in SW. Instead I like to add sketch segments in the 2D drawing to represent the actual weld bead. This works out great for our welding department, because most of them do not know how to read real weld symbols.
The problem is that this can get very time consuming if I have staggered fillet welds, 1.00" long every 3.00". That's a lot of segments to add. Is it possible to copy or linear pattern sketch segments in the SLDDRW? If so, how?
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Copy/pattern sketch segments in SLDDRW?
Sounds like you need to add the "Linear Sketch Step and Repeat" button to your sketch toolbar. Sketch a cute little arc, click the button and repeat to taste for the first bead. Select this bead and repeat it again.
Ray Reynolds
