Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Just wanted to let you know that I registered today, and your site is fantastic. I found solutions to problems that I have been encountering for months!..."
Geography
pathfinder9909 (Chemical)
28 Jan 04 17:47
Is there anyone in the world that has any idea where I can find a lockout device for a PVDF valve(same as a pvc valve)?
moltenmetal (Chemical)
30 Jan 04 7:48
The trick is to buy the right brand of valve.  An Austrian manufacturer called Praher makes a very nice PVDF true-union ball valve with a locking handle.  They make the same design in PVC and PP as well.
If the valve is already installed, you'll probably have to get something fabricated- a bit rough when the body hasn't got a place to fasten anything to it...I wouldn't recommend thermally welding anything to the valve body. You could fabricate a u-clamp type arrangement that entraps the handle and prevents it from being rotated- but you'd need tools to remove it.
scottguitreau (Chemical)
23 Jun 05 15:52
What is the reason for locking it out? If it is simply to keep someone from opening it, a danger tag or an FYI tag indicating not to turn the valve is what we use. This may be a little less than what looking for, but it will suffice. Otherwise I would have to agree that a U-bolt design would be best.
jdarco (Chemical)
23 Jun 05 17:40
Look at www.haywardindustrial.com  Follow the links to valves and flow control products.  They have a lock out cover that goes over the handle and locks together.  It is made for their valve, but I suspect it will fit others.  I've see other people with similar designs...maybe McMaster Carr or Lab Safety?
Close Box
Join Eng-Tips® Today!
Join Us             Close
