Urea Tank venting requirements
To all,
A client of ours wants to convert an older mild steel tank (20,000 gallons) to hold Urea. The urea solution will be between 32 and 40%. The tank will be located indoors and is a horizontal ASME-VIII vessel with a MAWP of 30 psig/FV
What are the venting requirements for a urea tank ? Will a conservation vent be required ?
I am aware of the special temperature maintenance requirements for urea but are there any other design features suggested for such a tank ?
Are there any references on the web for urea tanks ?
Thank You....
MJC
Thank You....
MJC
RE: Urea Tank venting requirements
A quick Google search gave me websites (terraindustries.com and rdtech.com) that mention both 304 SS pressure vessels (w/o mention of solution %) and CS API-650 tanks (for 50% or less solutions). Note sure is this gets you started
Steve Braune
Tank Industry Consultants
www.tankindustry.com
