Custom Menu Problems.
Does anyone know how to create a double line menu label. I've heard of this being done but can't find out how to do it.
RE: Custom Menu Problems.
http://www.afralisp.com/tutor.htm
(That is a good site to bookmark for customizing tutorials)
Flores
Steve Smith, C.I.D.
Product Engineer
Staco Energy Products Co.
www.stacoenergy.com
[&2. FINISH: APPLY TEFLON PENETRATED HARD ANODIZE COATING PER MIL-A-8625 TYPE III, CLASS 1, TO ALL SURFACES EXCEPT WHERE NOTED. BUILD-UP PER DIAMETER TO BE .002 INCHES MAX. RACK WITH ELECTRODES.]
I'd like this to display this on 2 lines on the pulldown menu instead of one continuous line.
Sorry for the poor description in my previous posts. Thanks
untested, try [control] + [enter]
cheers,
(just copy and paste into Notepad, it wordwraps here on the net)
In this example, "Coating_Note" and "SSTube_Note" are the names of the blocks.
// Notes.mnu
// Inserts note blocks into drawing
// This menu assumes that the blocks are in the support path.
// Helpstrings are displayed in the status line.
***MENUGROUP=Notes
***POP1
Header [Notes]
coatNote [&Coat Note]^C^C-INSERT;Coating_Note;\;;;
SSTubeNote [&SS Tube Note]^C^C-INSERT;SSTube_Note;\;;;
***HELPSTRINGS
CoatNote [FINISH: APPLY TEFLON PENETRATED HARD ANODIZE COATING PER MIL-A-8625 TYPE III, CLASS 1, TO ALL SURFACES EXCEPT
SSTubeNote [Stainless Steel Tubing: TP304 or TP316, seamless; made to ASTM A269-90. Mill source certificates required,
including heat number and chemical analysis.]
Flores
