Ground plate thickness of 1GHz monopole antenna
How do I determine the thickness of the ground plate of a 1GHz monopole antenna?
Thank you.
RE: Ground plate thickness of 1GHz monopole antenna
9mm @ 50Hz
0.9mm @ 5kHz
90µm @500kHz
9µm @ 50MHz
0.9µm @ 5GHz
2µm @1GHz
Metals other than copper will give the same order of magnitude of skin depth. What you need is a large area of ground plane under the monopole. I would say a radius equal to the monopole height would be a minimum, and maybe 3x the radius would give as much benefit as you could get.
