Geometric Mean Radius calculation with Mathcad
I am trying to calculate the GMR (Geometric mean radius) of a two layer (over the core wire)conductor. I have access to mathcad. Can anyone explain how to do this?
Also, I saw a gmean function in mathcad, but there is no explaination of how to set up the matrix required for the calculation.
Thanks.
RE: Geometric Mean Radius calculation with Mathcad
But I haven't tried it - I usually find it easier to get GMR from the wire manufacturer's standard tables.
If the central wire is steel, it all falls down because of the magnetic differences between the ferromagnetic core and the diamagnetic aluminium outer conductors.
Bung
Life is non-linear...
