Part2: Minimum clearance of live parts
Hi Again,
Let me take the "Minimum clearance of live parts" post a little further.
I have the following splitter trough in my plant. It was made by a local switchgear manufacturer. The specs are given below:
Phases: 3
voltage: 600v
Current: 800A
Bus: Copper, non-insulated 1/2" x 1 1/2"
Phase to Phase spacing: 3"
Phase to ground Spacing: 1"
RMS sym Rating: 25KA
Insulator spacing: 7" (4 Insulators/phase, 33" bus,i.e. 6" overhang on ends)
This splitter was never tested. However, the manufacturer says that based on it's calculations, the KA rating is good (it's always good until a fault occurs...).
Does anyone think the above Fualt rating seems reasonable... maybe a formula...
Thanks again
Tulum
Phases: 3
voltage: 600v
Current: 800A
Thanks again
Tulum
RE: Part2: Minimum clearance of live parts
A is copper cross sectional area in circular mils. T is time in seconds.
25kA gives a 10s clearing time. Maybe the switch contacts are the limiting factor?
