Anti-Slip Tread for >450F, Corrosive Environment
I have an application that needs to bond a rough surface (Ra 300-2000) to a 5" radius cylindrical mild steel part. The challenge is the part is used in a >450F continuous and HCl vapor environment.
Any suggestions for both the rough surface and bonding technique?
I'd love to find a shrink tube with rough outer surface. I'd also welcome a combination of an anti-slip or abrasive sheet (at least 18" long) and a bonding adhesive or tape to hold it in place. The high temp and HCl seem to rule out many options.
tjw
tjw
RE: Anti-Slip Tread for >450F, Corrosive Environment
aspearin1
aspearin1
Do you have any leads on who could do this service? Is it possible to do it "in-house", not necessarily on the machine, but at the plant site? (I can search this out myself if you don't have a lead.)
Thanks again,
tjw
aspearin1
