exporting results out of Ansoft Designer SV
Hello there,
i was wondering if it is possible to export the simulation results achieved with Ansoft Designer v1.0 SV. I want to use the results (say voltage over frequency) in Excel.
I want to compare the Simulation results with measured results in one diagram. Does anybody have a hint?
RE: exporting results out of Ansoft Designer SV
David
Here is the response from the ANSOFT AE to your question.
"It appears that the only way to get data out of Designer SV is either to
export a touchstone file, or to create a data table of the traces that you want, and right-click and Copy to file."
Hope this help,
David
