Solenoid Noise
Solenoid Noise
I am required to design a low noise solenoid. It is a tubular solenoid stroke is about 0.2 mm. On opening the armature hits the stop. Both are flat. Coating the surfaces can reduce noise, but the durabilty is not good, and it is questionable if the coating just reduces the force by increasing the gap. I am considering making the 2 flat surfaces cones of different angles to dampen the impact, but would like to know if anyone has developed a method of reducing the impact that is simple and durable.
Greg
Greg
RE: Solenoid Noise
I for one would vote to hear the click of the solenoid. It's a tell-tell indication (audible) that something happened as a result of input; etc.
But if you wish to dampen that out, I guess you need to add some sort of low durometer bumper or spring to absorb the impact of the plunger.
Sorry! I'm not much help here.
regards
pennpoint
RE: Solenoid Noise
RE: Solenoid Noise
You could also use a an air dashpot, but it would have to be customized due to the short stroke. Go to
www.airpot.com
Please note: I want to be upfront and tell you that I work as an engineer for Airpot an am not trying to sell here, I'm just telling something about a product that I know about.
RE: Solenoid Noise
