I-deas newbie question
I'm using I-deas 10. For a drafting picture, on the lower left or right corner, there is a box specifying parts number, name...etc. What is the name for it? I don't know how to get that thing to show up on my screen.
Edward
Edward
RE: I-deas newbie question
Either way, as the 'new' drafting now uses symbol files (.sym) for the titleblock insert (for IMS9 column one and either row 4 or 5 [in drafting] depending on which menu's you use), you can simply create whatever titleblock you'd like to use (using said drafting, etc) and then save it out as a symbol.
Assuming you setup standard locations, sizes, etc, you'll be able to pick the correct symbol when you pick a certain size, etc.
Does this help?
-e
