Does save as pdf really work with sp2.1?
Just a little check
Is it just in our office Save as pdf stopped working after installing sp2.1 (Checked several times and its not sp2.0)
We went from sp1.0 to sp2.1 and now it dosen't work:
First the progress bar, "Generating pdf" and everything looks OK but in the end we just get:
"An unknown error occurred during the creation of the pdf"
Best Regards
/Sam White
RE: Does save as pdf really work with sp2.1?
Have you tried my Alternative reinstall? FAQ559-507
I just tested it in SP2.1 and it works fine here.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
I will try your suggestion before reinstalling.
Best Regards
/Sam White
Good Luck!
Timelord
I might just be a coincidence that it doesn't work after you installed the SP.
Scott Baugh, CSWP
FAQ731-376
Mr. Pickles
My initial install was from CD's
Timelord
This worked for me. In a perfect world I should not have had to do this, but.... oh, well!
Thanks for the fix method, it worked for me.
Timelord
We did complete uninstalls on all 29 systems. Both via control panel ,regedit and manual folder removal to get everything. We installed the new Oracle/SmarTeam and SW2004. Every system was done the same using a cheat sheet with check-off boxes (took 5 people all day Saturday). Then we patched to SP2.1 yesterday once we were sure it was all behaving and to fix a smarTeam issue (we usually let them sit a while until we hear the patch is OK). Today I added PhotoWorks 2 and FeatureWorks on my system (I am the only one with these add-ins - individual licenses - from before the days of SW Office.)
Save As PDF works perfectly on all our systems. However, I would add the a few of us have full-up Adobe Acrobat and will continue to use it becuase it is MUCH faster.
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
A hobbit's lifestyle sounds rather pleasant...... it's the hairy feet that turn me off.
