Dimensioning accross broken view
I am trying to dimension a long part that has a hole pattern that runs the length of the part. Once I break the part to fit it on the format, I can't dimension accross the breaks. Is one of my settings wrong? It seem that I used to be able to do this.
Kim
RE: Dimensioning accross broken view
This much I know....
If you are creating linear dimensions across a broken view, you must dimension to the center of the hole and not the hole axis - use the query select and pick "center".
I am not sure whether or not this will work with ordinate dimensions.
I guess the other option would be to redefine your hole pattern to your part datum edges - and "show" dimensions.
A lot more work....
Hope this helps,
JW
Thanks - That worked great! It seems impossible to remember everything and this forum helps a lot.
