Sealing of ButtWeld Valve ends for Cryogenic Testing
Dear All,
        I would like to know if anybody has ever faced the problem in object.
    Having to perform cryogenic tests on butt-welding valves, it is not easy to obtain a good sealing of the test caps, due to the particular shape of the ends...
    Is it possible to have, somehow, a good (flat) sealing surface, on which the gasket can be centered and compressed properly?
    In addition to this, what kind of material would you use (see also Thread408-82258)?
Thanks and Regards,      'NGL
