Exploded Assemblies when opened
Hi All,
In the last month I have noticed that when I open assemblies there default view is exploded.  I am woundering why these assemblies are coming in as default exploded, which in the past they were not exploded.  Is there a config.pro option setting this?
It's not a big issue just a little thing that was bugging me.
Thanks for any info.
Tofflemire
RE: Exploded Assemblies when opened
You did not mention what version you are running, so I will make a pass at in using Wildfire:
View, Explode, Exploded View ... toggles Exploded View "On/Off".
When you save the assembly in Exploded View "On", you open the assembly in Exploded View "On" just like if you saved the open the assembly in Exploded View "Off".
