API code for seperating individual prt files from Design Table config.
hi,
Has anyone  API coding to seperate indivdual files from design table config file?.
i already created multiple configurations (nearly 60 configurations) using design table.but my client needs these config files as a single, separate, individual file.
anybody using API macro for separating the config file as individual files? pls send the api coding....
thanks,
Murugan.S
Design Engineer,
GlobalSoft Pvt Ltd,
New Delhi, INDIA.
murugan_subham@yahoo.com.
RE: API code for seperating individual prt files from Design Table config.
I have not tried the following macro, but it is supposed to do what you want. It is not mine so I cannot take credit for it & unfortunately I do not remember where I downloaded it from. Hope it helps anyway.
Option Explicit
    Sub main()
    Dim swApp As SldWorks.SldWorks
    Set swApp = Application.SldWorks
    Dim swModel As SldWorks.ModelDoc2
    Set swModel = swApp.ActiveDoc
    Dim swConfig As SldWorks.configuration
    Set swConfig = swModel.GetActiveConfiguration
    Dim fname, ext, current As String
    fname = swModel.GetPathName
    ext = Mid(fname, InStr(fname, ".")) ' extension with leading dot
    fname = Mid(fname, 1, InStr(fname, ".") - 1) ' path + name without extension
    current = swModel.GetActiveConfiguration.name
    Dim configs As Variant
    configs = swModel.GetConfigurationNames
    Dim i As Long
    For i = 0 To UBound(configs)
        If Not swModel.ShowConfiguration2(configs(i)) Then
            Debug.Print ("Could not switch to config " + configs(i))
        Else
            Dim name As String
            name = fname + "-" + configs(i) + ext
            Dim err As Long
            Dim warning As Long
            Call swModel.SaveAs4(name, swSaveAsCurrentVersion, _
                swSaveAsOptions_Copy + swSaveAsOptions_Silent + swSaveAsOptions_AvoidRebuildOnSave, _
                err, warning)
            Dim newdoc As SldWorks.ModelDoc2
            Set newdoc = swApp.OpenDoc(name, swDocPART) ' works only for parts at the moment
            If Not (newdoc Is Nothing) Then ' let's remove the unneeded configs
                Dim j As Long
                For j = 0 To UBound(configs)
                    If (i <> j) Then newdoc.DeleteConfiguration (configs(j))
                Next j
                swApp.CloseDoc (name)
            End If
        End If
    Next i
    swModel.ShowConfiguration2 (current) ' revert to current config
End Sub
CorBlimeyLimey, Barrie, Ontario.
Sign on a Barrie restaurant reads, "We serve Molsons, but we only smoke Ribs"
FAQ559-863
Do you need to do this an a regular basis?  If not I would think that it would be much less time consuming to just make multiple copies of the file, then go in and delete all but one configuration in each.  It would seem that in the time taken to ask the forum, write up, install and debugg the program you could do it manualy.  (Not suggesting there is anything wrong with the macro CBL posted - there's always some debug of some sort with new stuff.)
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
A hobbit's lifestyle sounds rather pleasant...... it's the hairy feet that turn me off.
thanks CorBlimeyLimey and JNR for quick reply.i'll check it out.
thanks,
Murugan.S
Design Engineer,
GlobalSoft Pvt Ltd,
New Delhi, INDIA.
JNR
I tried the macro last night & it worked...sort of....it made copies of the file complete with all configurations and left each one with the relevant config active. So you have to go in & delete all the unused or unwanted configs anyway. So you were right. Oh well, you never know unless you try.
It could probably be modified to work properly.....if I knew what I was doing!!!!
murugansubham
Did you have better luck?
FAQ559-863
Hmm.... interesting apparently a Macro to make multiple copies of a part - one for each configuration (whether in the DT of not?).  That in itself could perhaps be useful.
Well, like I said it is often a case of do I need this once only, or is it something I need on a regular basis?
