Multiple layout printing problem
Im trying to set up my pagesetup to print all of my layouts, I have a drawing with 25 layouts in it.
I setup the pagesetup to print .pdf's and the first one works fine but then on the rest of them it writes the .pdf fine but it doesnt carry over the page set up settings, like the zoom, it's only getting about 1/10 of the bottom left of the drawing.
I need help I have tryed everything, Im new to using layouts as we nomally work & print from  model space.
I'm using autocad 2002.
thanks in advance,
RE: Multiple layout printing problem
YOU NEED TO MAKE THE SAME PAGE SET UP FOR ALL OF YOUR LAYOUTS.  THEN IN THE PLOT DIALOG BOX YOU CAN CHOOSE PLOT ALL LAYOUTS. AS LONG AS YOU HAVE THE SAME PAGESET UP FOR EACH LAYOUT TAB YOU SHOULDN'T HAVE ANY PROBLEMS.
