maximum piston speed?
in my quest for more useful knowledge i am wondering what kind of piston speeds are the limit? i know some of you guys out there deal in F1 and such. i had jotted a number on a small piece of paper an F1 guy told me a few months ago but i have misplaced it and it is important now. i think it was 28m/s or was it f/s? thanks for the help i am really looking for a max this engine will only run for 200 miles then be rebuilt. i am trying to maximize breathing with the best trade off of stroke and rpm.
RE: maximum piston speed?
The actual true maximum, as opposed to mean speed, also depends on the rod length as well as revs and stroke length, but people just normally talk in mean values.
basically the measure of power in a basic view is the amount of air(oxidizer) and fuel combusted per unit time. some people will run short stroke smaller displacement with higher rpm to yeild a certain amount of combusted fuel. a larger stroke with less rpm can yeild the same amount, but the idea is to do the most. and in either case it is limited physically by piston speed.
The best advice I can give you to date is that piston speeds are moot.
Chumley
With improved materials, design and manufacturing techniques, those days are long behind us. In the realm of purpose-built high performance engines, mach index (intake charge velocity) will bite you in the backside long before the tensile limits of a connecting rod will.
Bryan Carter
The maximum piston velocity was around 38m/s.
This was 200 miles of WOT track testing on a super speedway. As we approached the 250 mile distance (we had a 300 mile race coming up at Motegi in Japan in less than 6wks) when we discovered that the pistons were now the weak link. The center of the piston was cracking (due to inertial forces of the mass of the material in between the 4 valve reliefs in the center of the piston) and causing catastrophic failures. We spent ~$250k as a band aid fix to this problem since we didn’t have enough time to have new forging dies designed, built and new pistons tested.
I still have one of the band-aid pistons as a paperweight. It showed signs of cracking @ 250 miles, but it lived 350 miles before a pencil sized hole burnt through the crown.
thanks for the good info. what kind of rings did you use at that speed. i was going to use something lightweight with gas porting. but there are a lot of options out there. any advice you have is apreciated. i have pretty much settled at a speed of 31 to 32m/s. my head wont flow much past that. not that you people really care.
just thought i would kick that info back to you guys. ssems to make sense though. if you have a mean speed of 28m/s or so it makes a little sense that you would have peak speeds a little higher. cnova the mean sped on you data is 24.4 m/s. most of the applications seem to stick right around 28m/s mean speed. but i had a very reputable engine builder say he has done mean speed of 32m/s before with a peak velocity of 50 m/s. but he says it might only last for 100 miles.
Those are the sayings of scientist and inventers of years past. Maybe they didn't want anyone passing them up???? LOL
That saying inhibits invention and science.
why did you use the beryllium copper rings? was it because of the weight or the springiness of the material?
We were experimenting with several different materials and coatings for our liners. Base materials ranged from cast iron to Be-Cu with hard chrome or Nikasil coatings, to an experimental Aluminum-ceramic fiber matrix.
The aluminum-ceramic matrix liners showed the greatest promise once we figured out how to 1) manufacture them (centrifugally vacuum cast), 2)then how to machine the castings and then 3) how to hone the cylinder bore to the proper finish. These 1st 3 steps were a "hemitsu" sp? (Japanese for big secret) project. Once we (the track development engineers) learned more about the materialused in these liners, we pointed out that the CART engine rules prohibited the use of composite materials in the internals of the engine. External use of composites (mounting brackets, sensor boxes, etc.) were OK.
Needless to say more than one person lost his job as a result of this oversight.
From the safety of my armchair I wonder if the best results might be obtained with the thinnest standard rings available, a low vacuum dry sump system with lots of scrapers, buying a few cams from a few can houses, fabbing an adjustable exhaust, then spending most of the rest on headwork and dyno time with a carburetion/fuel injection specialist.
Or simply crank up the boost on the turbo.
As I understand it, the greatest tensile stress in the rod is a TDC during the exhaust stroke, where there is no gas pressure to counterbalance the inertial loads. As a result the alternate tension and compression loads on the rod can quickly lead to fatigue of the rod, usually in the thinnest section just below the pin boss.
There is no real fixed limit. A lot depends on what the rod is made from, piston weight, and how long you expect it all to last.
From the postings:
At 5000 rpm your piston goes from a complete stop to 66mph in 2 1/4 inches in just .003 seconds.
Interesting Warrior Engine facts/figures:
Engine RPM/ Piston Velocity mph/ G's exerted on rotating mass.
1000 / 13.25 / 40.49
2000 / 26.50 / 161.98
3000 / 39.76 / 364.47
4000 / 53.01 / 647.95
5000 / 66.26 / 1012.43
6000 / 79.52 / 1457.90
7000 / 92.77 / 1984.36
For Comparison at "redline":
Chevy 350
Engine RPM/ Piston Velocity mph / G's exerted on rotating mass.
6000/ 62.20/ 1140.15
Formula 1 engine
17,000/ 83.56/ 361.27
2004 R1 Engine
12,500/ 78.58/ 250.12
2004 R6
15,500/ 79.98/ 315.69
2004 V-Rod
9000/ 76.14/ 174.50
OK guys for those who are not bored by this...here's the math.
I did my math in feet, just to keep from having to change the numbers up at the end, but trust me it's the same.
Warrior Stroke=113mm or .370735 feet.
Distance traveled by crank per revolution 1.16632 feet (remember that the circumfrence is "pie"* diameter)
Revolutions per minute=5000.
Distance crank travels per minute=5831.608202 feet
Distance crank travels per hour=349896.4921 feet or 66.2682 miles per hour.
So if the crank shaft is traveling at this rate the pistons reach this max velocity twice per revolution at 9 o'clock and 3 o'clock since they are traveling at the exact speed that the crankshaft is, remember at 12 and 6 o'clock the pistons are "stopped".
To calculate the G-Force you have to take your revolutions per second (rps) which is 83.3333 (at 5K)and figure how long it takes for one revolution or .0120 seconds (1/83.3333). The piston goes from a dead stop at 12 o'clock to full speed (or 97.1934 ft/second) in 1/4 a revolution or in .0030 seconds. So the average acceleration in a second needs to be calculated or how many times per second does this event occur 1/.0030 = 333.333 times per second, now multiply this by the speed at full acceleration (97.1934*333.333) gives the figure of 32397.82 ft/second/second as the average acceleration. G-Force is 32ft/second/second. Divide 32397.82 by 32 to get the average G's exerted on the parts...or 1012.432 G's. Whew....if you hung with my math you deserve a gold star...lol
A piston weighs in at around 400grams, so at full G's right when it is stopping it "weighs" an astonishing 892.79 lbs!!!
The g's are exponentially related to the RPM and crankshaft length relationship. The Warrior crankshaft goes from 33mph at 2500rpms with 253G's to 66mph at 5000rpms and 1012G's. At 10,000 it would be 132mph with 4050G's.
The F1 crankshafts are, I forget exactly, but like 1.65 inches. Do the math Gotta, no scare tactics here, pure physics. I was just joking about the connecting rods, but it is something to think about when you start wanting to get a few more revs out of your bike.
This calculation has nothing to do with bore or weights in the calculations demonstrated.
Rob Hughes
Orient Express Powersports
That certainly is a man sized stroke on that Warrior. Makes the stroke on anything else look like just a bit of vibration.
Your example will be within a few % of actual I expect.
pat pprimmer@acay.com.au
Chevy 350
Formula 1 engine
17,000/ 83.56/ 4324.97
2004 R1 Engine
12,500/ 78.58/ 3001.46
2004 R6
15,500/ 80.89/ 3831.51
2004 V-Rod
9000/ 76.14/ 2094.07
Yikes...the math gremlins got in my excel program and jacked up my F1, R6, R1 and V-rod figures....sorry all.
4300+ g's....holy sheet batman.
http://scarbsf1.com/BMW_P83/index.html
http://forums.atlasf1.com/showthread.php?s=&threadid=61653%20http://scarbsf1.com/BMW_P83/index.html
Cheers
Aorangi
I try to put my little experience here for my 1st post.
Main limit for the mean piston speed comes from an aerodynamic limit.
Since mps=IM x Cso x Cem x Ar/S
IM= MACH Index, which has a top limit of 0.6 (see graph on TAYLOR-the internal combustion engine in Thery and practice)-MIT-London
Cso= Air speed in normal conditions is 340m/s at sea level
Cem= mean efflux coeff.is 0.436 (F1 engines middle '90s)
Ar/S= geometric area of valves/area of piston is 0.3 (F1 engines middle '90s)
So, the resul for the limit of the MPS is 26,7 m/s.
More or less MPS of 27m/s is the actual limit in F1 engines.
Bye.
Alex
Cheers
Greg Locock
InstantaneousPistonVelocity = -2*PI*(RPM/60)*(Throw/12)*(TAN(RodAngle*PI/180)*COS(CrankpinAngle*PI/180)+SIN(CrankpinAngle*PI/180))
InstantaneousPistonAcceleration = -(RodLength/12)*(COS(RodAngle*PI/180)*InstantaneousRodAngularVelocity^2-SIN(RodAngle*PI/180)*InstantaneousRodAngularAcceleration)-(Throw/12)*(COS(CrankpinAngle*PI/180)*CrankAngularVelocity^2-SIN(CrankpinAngle*PI/180)*BigEndAngularAccel)
All dimensions are in inches, angles are in degrees, angular velocities in rad/sec, angular accelerations in rad/sec^2. Outputs are in ft/sec for piston velocity and ft/sec^2 for piston acceleration.
BigEndAngularAcceleration allows input of crank rotational acceleration.
As a side note, the rather largish spreadsheet that I took the above from gives -2320g (at ~0.070* ATDC) and +1259g (at ~214* ATDC) for the maximum negative and positive maximum piston accelerations for a Chevy 350 at 6000 rpm with 5.7" rods and 0.020" piston pin offset. Maximum positive and negative piston speeds are 95.4 ft/sec (~286.01* ATDC)and -95.2 ft/sec (~74.47* ATDC) at that rpm. It also gives a 10000-ish number for peak g's for the BMW P83 engine.
I need to work on the ATDC angle lookups for the max values a little more, though.
Norm
I'm surprised it took this long to reach the point about maximum acceleration. I always thought that the real issue is the maximum (not average) acceleration and the stress and fatigue this causes. One reason for longer rod ratios in high rpm engines is to reduce the max acceleration at TDC (there are also benefits from being near TDC for longer and better rod angularity during the combustion stroke.)
I found some interesting piston kinematic spreadsheets on this page (and page 2.)
http://e30m3performance.com/tech_articles/engine-t...
Saw an F1 piston at the Mahle stand at Automechanika last month and it was extremely short. The height reduction seemed limited by the pin diameter. The pin length was about half the piston diameter to reduce weight.
cheers, derek
ie
omega squared . r
At TDC and BDC all the elements are in a straight line and accelerating in the same direction
Jeff
Without attempting a rigorous derivation, decreasing the angularity of any given rod has the effect of raising the piston in the bore while increasing its angularity has the opposite effect. So as you approach TDC both effects are raising the piston. After TDC, both are lowering the piston. Approaching BDC, the crankpin motion is lowering the piston while the reduction in rod angularity is raising it. After BDC the crankpin raises while rod angle lowers. Hence, taking these motions as velocities and differentiating for acceleration would be expected to show asymmetric TDC vs BDC results as well.
It's perhaps interesting as a side note that for most common rod:stroke ratios there are two relative maximum positive accelerations and (assuming zero pin offset) that the acceleration at BDC is a relative minimum (although still positive). You have to get up to about a 6.6" conrod on that 350 for a single maximum positive acceleration to occur at BDC.
Norm
the two effects are
(1) crankpin movement, and
(2) change in rod angularity
Norm
I must confess I did not plug into the formula but logically this must be true.
Interesting approximation. That's based on the "piston motion is a combination of a sin and a cosine" approximation, right? How does that compare to a precise calculation? As I recall, it's off by a couple of percent in a few places.
Piston axial acceleration (kinematic, closed-form solution for constant crankshaft angular velocity):
-a*cos(o)*w^2 + (a^2*w^2) * (1-2*cos(o)^2)/(sqrt(r^2-a^2*sin(o)^2) - (a^2*sin(o)*cos(o))^2*w^2)/(r^2-a^2*sin(o)^2)^1.5
where
a = crank throw
r = rod centers length
o = crank angle in radians
w = crank angular velocity in rad/sec
The above is based on taking two derivatives with respect to time of the formula for piston position:
position = a*cos(o)+sqrt(r^2 - a^2*sin(o)^2)
I can provide a (more complicated) version if you want to include pin and crank offsets from the cylinder axis, or crankshaft angular acceleration.
let r = rod ratio = (length conn rod)/(stroke)
let ? = crank angle from TDC
let ? = d?/dt = engine speed (radians/time, not rev/time)
let u = piston position from mid-stroke)
let ú = du/dt = piston velocity
let ? = d²u/dt² = piston acceleration
let ? = 2r
let ? = (?² - 1 + cos²?)^½
And first note that for infinitely long conn rod (r=?), piston motion approaches sinusoidal, where
max u = a
max ú = a?
max ? = a?² for constant engine speed (d?/dt = 0)
Actual motion for pistion (finite conn rod length) can then be expressed as ratio to max sinusoidal motion:
u/a = -? + ? + cos?
ú/a? = -sin?[1 + (cos?)/?]
?/a?² = -(cos? + [(sin²?)/?]•[(cos?)/? - 1])•[(cos?)/? - 1]
These normalized motion equations approach sinusoidal for larger rod ratios, with max/min values of ±1. The amount that the normalized velocity and acceleration max/min values exceed ±1 represent the amplification due to non-infinite conn rod length. Again, engine acceleration was neglected in deriving normalized acceleration equation.
Note that maximum piston acceleration is amplified over sinusoidal max (a?²) by factor of (1 + 1/?) = (1 + ½/r). Trends pointed out by Norm above can be seen (what's with the Structurals hanging out here?....)
FWIW, I've heard max piston accelerations for near-current F1 engines as being around 10,000g, as mentioned above. Same source reported engine accelerations of 25,000rpm/sec.
Looks like some fancy characters that showed fine in "Preview" of my post above didn't survive actual posting! They all turned into question marks!
I hope to repost with corrections later...
Here's some equations for piston kinematics I had worked out some time ago. They might even be correct!
let c = conn rod length
let s = stroke
let r = ½s
let p = "rod ratio" = c/s
let Q = crank angle from TDC
let w = dq/dt = engine speed (radians/time, not rev/time)
let x = piston position from mid-stroke)
let y = du/dt = piston velocity
let z = d²u/dt² = piston acceleration
let a = 2p (twice rod ratio)
let b = (a² - 1 + cos²Q)^½
And first note that for infinitely long conn rod, piston motion approaches sinusoidal, where
max x = r
max y = rw
max z = rw² for constant engine speed (dw/dt = 0)
x/r = -a + b + cosQ
y/rw = -sinQ[1 + (cosQ)/b]
z/rw² = -(cosQ + [(sin²Q)/b]•[(cosQ)/b - 1])•[(cosQ)/b - 1]
Note that maximum piston acceleration is amplified over sinusoidal max (aw²) by factor of (1 + 1/a) = (1 + ½/p). Trends pointed out by Norm above can be seen (what's with the Structurals hanging out here?....)
That's the basic position formula that I used (piston pin offset being taken as an algebraic correction against 'a*sin(o)'). I've been looking for some old derivation notes that may still be around somewhere. But I recall having used the rod angle as well as the crank angle in working the various velocity and acceleration components. Seemed simpler at the time . . .
Have to admit, I hadn't considered the possibility of crankshaft offset.
Norm
Metal/matrix/composite (MMC) cylinder applications can be found if you do a search in Google. Porsche and I believe, Toyota use this material currently.
I worked in the engineering/testing dept. for a piston manufacturer a few years back that was experimenting with the material as a piston alloy. Machining is a real challenge.
Will
